Enables router discovery advertisements on the VLAN and the processing of router discovery messages.
| vlan_name | Specifies an IPv6 configured VLAN. |
N/A.
This command is only valid when the specified VLAN has an IPv6 address associated with it. After IPv6 Router Discovery is enabled on a VLAN, router advertisement messages are regularly sent on all ports associated with the VLAN.
The following example enables router discovery for the VLAN "top_floor":
enable router-discovery vlan top_floor
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
